The firing pin is not returning.
I notice Axminster do a replacement pin, but I am pretty sure this will NOT solve the problem.
I've stripped it apart tonight and rebuilt it. The pin 'o' ring is a good seal in the piston.
It seems like there should be 2 air pulses, one to fire, one to return ??? the return one isn't working.
The pin is staying down a bit, and in turn the next brad is not loaded, but the pin still leave the mark as if it's working.
I noticed I am using less brads than usual !!!! a bit worrying, for the work I have sent out !
So ... anyone had this problem and solved it ?
Should I just buy another ... at £50 it's not much, considering I use it all day - most days.
Rich
Rich
