avoiding end grain tearout when using router
mickthetree
24 Feb 2006
Tring - Herts
Hi all
I have a project in the pipeline to mass produce some items. My plan is to make and stick a perspex template to the wood that I follow with a bearing guided router bit, having cut the wood to near size on the table saw. Essentially a rectangle with rounded corners.
I could route two corners then flip the work and do the other two but this would mean removing them template and aligning it accurately on the other side.
I do have a large disc sander and I get OKish results but I think speed and accuracy would be best if I used the router.
Ah ok so I would flip the work then lower the bit and pick up the other bearing. Ok I like that. Reasonable cost compared to the trend equivalent too.
thanks Marcos. I thought they only sold them in multiples! but they do singles at the bottom of the drop down.
i saw that too when i found the link for you. quite scary if you dont look properly!
