Attention Sharpening Nerds
A
Anonymous
Guest
Ta Philly
I am no sharpening nut by any standards but I am an engineer and academic and it is nice to see reasonable tests carreid out many times and analysed to some degree in an effort to provide meaningful results (rare)
Interesting :wink:
A
Anonymous
Guest
jaymar":1netogi2 said:
Does being an academic mean you don't need to use the spell checker?
Waht' s a spollcegger????
Being an academic means I am very busy and must type faster than I am capable of - hence sometimes (most times) there are mistakes :) I suspect that you will find that the meaning always comes through though :wink:
By the way, there is only one error in the above post (i and e swapped around) - a record!!!!
Tony
PS the forum spellchecker stinks anyway!!!!
andrewm
30 Oct 2003
Cambridge, UK
Interesting that the microscope that this guy is using to photograph the blades looks to be the same one that Pete W recommended to Alan for photomicroscopy recently in this thread over here.
Andrew
Pete W
31 Jan 2004
London
Actually, he's using the older model, the QX3; the newer QX5 is meant to be much better.
And am I alone in thinking that the more I learn about sharpening, the less I know :??.
A
Anonymous
Guest
Seems to be a rash of academics on here.
Lets hope it doesn't turn into an epidemic :wink:
Alan Holtham
4 Aug 2004
Cheshire
Andrew
Yes, I noticed that as well. I think for the money it might be worth a try, the kids can always play with it if all else fails! Thanks to everyone for all the helpful replies to my original question. :)
Alan
