Attaching my workbench top to frame?
Tetsuaiga
4 May 2012
UK
I have started making my top for a workbench, it is 6cm thick douglas fir, 70cm wide, around 2m long.
Would I be best fixing the top onto stiles or is 6cm enough to try morticing the legs in? I'm not sure if i'd get enough rigidity that way.
I want to do things like hand planing so the bench needs to be reasonably solid. I'm thinking I can get away without rails which meet the top, maybe just ones lower down to stiffen the legs.
I assume you are building the French type of bench, as you mention morticing.
6 cm is pretty thick, but if you are having doubts, you can always laminate a 2x6 at the front and one at the back
and thus achieve the usual thickness.
Continental benches aren't consistent in their thickness either. Only the area around the dog-holes is around 10cm or so,
while the rest is similar to the 6cm you intend to use.
You probably have a reason for it being 70cm, as this is wider than most.
Thanks, I hadn't really thoguht of making it thicker in just select areas. The width is for assembly and sometimes I use router sled to plane/thickness wide pieces.
I think i'd rather not go with the leg mortice option as it seems trickier, but it seems a fairly common method alongside presumably bolting or gluing to the frame, i'm not really sure what the pro and cons of each are though.
Keep it simple.
My bench has a mixture of frames with horizontal rails with screws through them and extra battens screwed into the uprights and the top. I was able to put the top in place and add the fixings from below. Much easier than getting several mortices in exactly the right places.
While it's quite nice to practice some skills building the bench I agree and think I will keep it simple and forget about the tennon legs.
