Just wondering if anyone have, are you able to cut precise cuts with it when cutting larger stock? Like for example 3x3 beam? Mine just cuts at some 2degrees off ( vertical ) obviously there are no adjustment for it, the horizontal mitre you can adjust cuts just fine.
I have bought this saw used (with some accessories missing/broken which i wasn't aware of) and maybe that why the guy sold it because it just didnt cut straight as well?
Also I don't believe its inaccurate because I cut such large stock with it, it seems to do the same thing even with 2cm thick material.
I have re-asambled everything, tightened every screw, put in a new blade- nothing seems to change it.
The reason I even bought this was that this was the only way I could cut 10cm thick stuff for cheap , I have electric bosch mitre saw which can cut only 6cm thick material , if you want one which can cut 10cm you must spend some £500+ :| which I do not have to spend on saw now.
