Any use for broken bandsaw blades?
GrahamRounce
26 Jul 2007
Bethnal Green
It seems a shame to just chuck a very nice piece of metal, well sharpened etc.
Any ideas? Or has anyone actually done something?
sunnybob
wysiwyg
11 Oct 2014
cyprus
Mostly, unless youre talking 1" wide, they are too flexible. By the time youve made a frame to hold them rigid its simpler to just use a more suitable tool.
AES
18 Feb 2011
Switzerland, near Basel
My scroll saw (Excalibur 21) will take bits of broken band saw blades, and I do have a couple of such which I use every now and then. But that would only use up a very few broken band saw blades!
spb
30 Dec 2019
Cambridge
I think the best use I've seen was Matt Estlea's sandpaper rack - the rolls go on a spindle, then the ends tuck behind a length of bandsaw blade to tear it off.
Sean Hellman
27 Dec 2009
South Dartmoor, Devon
Even blunt ones make excellent frame saw blades. I use end of life 100mm wide blades for making tools from especially riving push knives for making fan birds. They are great for scrapers as well.
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
Use a 8" lengtth to make a Kerfing plane. Basically a way to make a starting kerf set at whatever thickness you want of veneer in a board all the way round to help you stay on the straight an narrow as you hand saw veneers. example below
novocaine
21 Jul 2014
Warrington
I ground the teeth of a length and made a few lock picks with it. :) the were a bit whippy.
I also made a few "extreme" scrollsaw blades, but I couldn't tension it.
in the end I turned it inside out, spotted it back together and left it at a mates workshop.
Ok,last ones a lie.
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
You mean, like, under guarantee?
If a relatively new blade breaks on the welded portion of the blade, most decent suppliers (Like Tuffsaws) would be happy to sort it for you because it means the weld has failed and wasn't fit for purpose, it's not really worth the hassle of having it re-welded though so they'll more than likely send out a replacement.
If you're pretty handy and you've already got silver solder and flux to hand you can solder it back together yourself fairly easily provided the blade hasn't crumpled into an accordion when it went bang, but I wouldn't rush out and but the stuff (which isn't overly cheap) just to put a single black back together. Although, if you're feeling savvy you can actually buy bandsaw blade stock in 100ft coils and solder them yourself which can work out cheaper than buying them pre-done.
