RogerS
Scratching my head about this little lot. All came in an Under Oven Housing from Magnet.
We have the drawer that needs the front panel fitting. There are two 'cavities' in the front that look as if something should slide up and to which the front panel is fixed.
We have a front panel with pre-drilled holes but are clearly outside the 'cavities'
and indeed Magnet recognise this as inside came two pieces of paper telling you not to use the pre-drilled holes. They reference to different front panels.
Trouble is neither reference my particular front panel. Neither do the pre-existing screw holes match up with those on either diagram.
So how to fit the front panel ?
I have two of these (Gizmo 1)
The arm swivels through 360 degrees. The gizmo falls out of those drawer slots so not intended to fit the front panel..or I can't see how. So if not fitting the front panel, what are they for ?
Then we have two of these (Gizmo 2)
About 75mm long. No idea.
Three bits of wood 2 off 605mm and one off 565mm.
and lastly a bit of grey plastic
Singularly lacking are any instructions other than the aforementioned irrelevant pre-drilled instruction sheet.
So......
if anyone has any ideas I'd welcome them. Have an email out to Magnet but who knows how long they will take to respond.
TIA
So......
TIA
