Any info on this old brace bit?
carpenteire2009
UKW Supporter
6 Oct 2009
Midlands, Ireland
This bit belonged to my great grandfather, I assume it is a screwdriver bit for use in a brace. It's made by Marples and the end appears to have been hammered at some point (I think it may have been "repurposed" at some stage in its life!). Was this bit designed for use in an older type brace (given that the shank is a tapered and square in cross section), rather than the more conventional 2 or 3 jaw brace I'm familiar with? Any info appreciated.
I think you are right; screwdriver bits to go in a brace were quite common, and the tapered square shank was the standard for many years. It's a very practical option and can be just as fast as a cordless screwdriver, with very good control. Your main problem now will be finding slotted screws; but a brace with a simple two-jaw crocodile chuck will also grip a hex shank cordless screwdriver bit neatly - and the batteries don't run out.
Your specimen looks quite a broad blade, so would be of limited use nowadays - so you could copy what I have done and set it in a handle, making a screwdriver which is a proper fit for the big cap screw on a plane iron.
It looks like someone has "sharpened" the screwdriver, which would need regrinding, if you intended to use it again.
BugBear
On the subject of brace bits, does anyone know where you can buy new center bits? I found a box of them in an antiques store recently, but they were asking silly money for them (and they would have needed a lot of fettling).
I don't know of anyone making them now.
Most of mine came from eBay, where they are fairly common in the Collectables>Tools>woodworking category. High postage is generally the deterrent, so look for lots local to you that you can collect.
If you need a particular size, and ever get up to Bristol, Bristol Design have a good selection to rummage through.
Most specialist tool dealers have a box of 'em, if they haven't thrown them out.
Not expensive.
Generalist antique dealers seldom have the "right" price on tools. They vary all over the place, by a long way, both up and down.
I'm always fascinated by antique dealers who can happily "put a price" on items they can't identify!
BugBear
Not sure about the tip needing sorting, as all the the ones I have are ground down to the point leaving a little flat in the same way as yours....
Got a close up shot of that area :?:
Andy
I've put a stock beech (file) handle on the bit, pic below. In answer to your queries, yes the blade does feature the Marples "shamrock" logo. The tip is crudely ground but does feature a small flat on the tip, unfortunately my camera won't allow me to get a good close up. I might clean this up on the Tormek.
I'd clean it up flat....on some paper on glass....the Tormek will give it a concave bevel and I am of the opinion that it just doesn't look right on a screwdriver....but I don't want to open that can of worms up..... :mrgreen:
Jimi
Too late - you just did! Concave screwdriver tips for ever! Death to the unbelievers!
BugBear
BugBear
Oh deary me.... (homer)
DOH!!! :mrgreen:
Jim
I have several of them and use them in My braces regularly, they are marvellous for removing slotted screws from door hinges and similar as you can put a tremendous amount of pressure on the brace pad to prevent the bit camming out of the screw slot and damaging it, a round disc of ply approx 6" in diameter with a dimple in the centre to take the brace pad helps to put pressure on with your stomach whilst turning the screw, very few screws can resist that, however tight or rusted. Grind it hollow so that the very tip is square and has parallel sides, (find a screw with a head the same diameter as the blade width and make the blade just thin enough to fit tightly into the slot, this will help to avoid the problem of cam out, ie the blade riding up the sides of the slot.
The picture on the right is the way to do it
Plover
Plover
Reminds me of my apprentice days, soon as I bought my bit and brace one of my journeyman asked me to try my new bit in a stuck screw, in a steel cast, machine moulding plate...You guest it, the screw head was part of the casting, but as the cocky young invincible lad I was, I fell for it - hook - line - and sinker #-o ...bosshogg
