Any Festool ks60 owners...
oobaa
22 Feb 2019
London
Hi there
If you own a KS60 could you do me a favour please?
I’m planning a mobile cart for a forthcoming purchase and want to know the depth (front to back) of the saw when it’s at 45*
Trying to establish its minimum footprint if you like
TIA
fezman
22 Mar 2017
South Yorkshire
Hi Oobaa
my kapex ks60 sits on a mobile cart which is 610mm deep (front to back) this accommodates the saw at zero degrees right through to the dust hose out the back.
I've done you two measurements the first includes the base front to back, the second is upto and including the cable tidy, but not the space for the hose (if that makes sense)
at 45 degrees it is approx 480mm or 560mm including cable tidy
the smallest is when it is at 60 degrees 400mm and 450mm incl cable tidy
You should be mindful that the KS60 has a "foot" under the knob at the front which requires extending down to give full support
Honest John
13 Dec 2014
Shaw, Lancashire
Fezman has got all the gen. he’s also mentioned that some space is required for the attachment of an extractor hose, and also the front support under the lock knob.
oobaa
22 Feb 2019
London
Thanks guys
One last question if you dont mind...
Is the cable tidy removable?
fezman
22 Mar 2017
South Yorkshire
It does look like it is removable, but it will only save you about 25-30mm at the back as the clamping knob for the bevel cut protrudes out the back too
oobaa
22 Feb 2019
London
25mm might make all the difference :)
I'm trying to fit a lot into a tiny space but keep things easy to access and move
