A
Anonymous
Guest
I am a bit concerned about my bandsaw motor. I was doing some repeat profiling on the bandsaw today and hence had it running continuously for about half an hour albeit with very little load. After I had finished I was cleaning up and noticed a hot electrics smell. The motor had become too hot to touch. It had become so hot I think it split the attached plastic casing that houses the (capacitor?). Although I cannot say for sure but I hadn't noticed it was split before. On opening this casing there seemed to be a little oily moisture on the plastic.
On further investigation it seems that when it is running the air from the motor fan across the fins manages to keep it cool but on stopping it begins to get hotter and hotter.
Do you think something could be wrong.
Its a Startrite 351SE that I've had for about three months and this is the first lengthy run it has had.
I've also posted on usenet in uk-diy but thought there'd be more bandsaw experience on this forum. I'd be interested in Kityuser's comments as I believe he has recently aquired a 351SE.
Roy
Roy
