Any Buying Recommendations For Good Quality Corded Drill?
pollys13
19 Apr 2009
Swindon
With this spec, 13mm chuck, 750w-850w, 2,000-3000rpm to be used with a Souber door lock morticer.
Cheers.
MikeJhn
Grunkel
2 Sep 2014
Kent
Admit I don't know the Souber kit, but can't it be used with a Router?
Just looked it up on the net, to answer my own question NO.
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
I tried the Souber and found it absolutely rubbish for the way I do lock mortices in doors which is the door laid horizontally in a pair of choks, it probably works well for doors that are already in place and hanging vertically. It also didn’t really perform all that well on solid hardwood doors, I think it’s best suited for hollow core internal doors more than anything.
Best piece of kit for the job is a portable Ryobi DM-20 hollow chisel morticer but they’re like gold dust and very highly priced second-hand. I don’t know why they stopped making them as they were absolutely perfect for the job.
Bosch make a good corded drill, but I can’t remember the model of the top of my head.
Sideways
26 Dec 2017
United Kingdom
Personal preferences here. Look at Metabo and Fein first. then Bosch.
3 year warranties appear to be standard these days for the better kit but don't forget to register immediately to get that. Put it off for a day and you risk forgetting and losing the extended warranty.
Be a little wary. I used to consider these brands as lietime buy tools and I have Bosch and Metabo that are 20+ years old, but I was very disappointed in a newer Bosch sander that was simply impossible to strip down to replace a failed bearing.
pollys13
19 Apr 2009
Swindon
Renewing my books at the library Saturday, while there, will have a look at Which magazine.
owen
5 Apr 2013
Buxton
I use a cheapo silverline drill on mine, cost about 15 quid, over the past 6 year I must have used it on about 200 doors. The morticers work a lot better if you give the bits a sharpen every now and then with a diamond stone.
johnnyb
13 Nov 2006
Biddulph staffs
I've used a dewalt drill on my sober and it's perfect. I'll get the number of it in a bit. I got it used off the bay £35
johnnyb
13 Nov 2006
Biddulph staffs
I also drill internal doors with the specialist bit. (if I've got 3 to 6 to do)
I like my latches to be centred and level!
Steveinthewoods
New member
28 Oct 2019
Lincolnshire
I've had a bosch professional for 15 years and it's renovated two houses and about to do a third without even a bearing replacement. Can't fault it
El Barto
20 Nov 2016
North Hampshire
I picked up one of those big Titan drills from screwfix recently, it’s a beast but has been really good so far, especially for the money.
johnnyb
13 Nov 2006
Biddulph staffs
to work with the souber the drill has to spin real fast. it needs to have good bearings and be lightweight as poss.
then it works as intended. never try and use a cordless. unless your drilling for latches. mortice locks are frightening!
