- Joined
- 11 Mar 2009
- Messages
- 1,321
- Reaction score
- 11
Just purchased my split air con unit and the company I purchased it from on ebay state the system is pre gassed and does not require a vac pump. Well, the system has arrived and after unboxing it I see a 3m length of copper pipe that needs to be connected to both the outdoor and indoor unit. This to me means it is not pre gassed as when I connect it all up there will be air in the 3m pipe.
The outdoor unit has a vac pump connection point and the instructions make mention of attaching a vac pump.
The item I purchased is here
http://www.ebay.co.uk/itm/BERGDORF-24K- ... 3d00197ce3
Thankfully, I do have a vac pump so I can purge the system of air before opening the refrigerant gas valve, but I think the company here are very misleading. They are basically advertising a unit as an easy install for Joe Bloggs, but in all reality they are just cutting corners. I think it's a bit naughty.
Open to comments if I am mistaken and you do not need to connect a vac pump.
