Any advice on how to do this?
MrTeroo
3 Sep 2016
Worcestershire
I want to make a new plinth for a Thorens turntable. Something like this:
It will need a 4mm groove routing around the top for a lid to seat into.
I have some sycamore i intend to use.
What would be the best way to create the groove and get neat corners? I have a Record 044c which I intend to use but would I be better doing ot before I join the four edges together or when they are joined together?
Also, mitred corners. Will they be strong enough just glued?
Here is a plan I made, hope it is readable.
Red is the plinth. Blue is the channel for the lid.
    207.6 KB
Thanks Nev,
Routing the channel before joining together would be the way I would attempt it, but I don't have the experience to go ahead without some confirmation.
Matt, I want to do this with hand tools. I have a Record 044c plane.
Thorens turntable, very nice.
Definitely groove it first after dimensioning the timber to size. Could you dowel the corners using a jig for accurate holes?
I don't have a jig.
Just looked at the link Nev supplied and splines look good in a contrasting wood, I might be brave and try that.
It's a TD-150 with a horrible diy plinth. It was the turntable only, build your own plinth version.
I have a nice Michell T/T.
Splines would be good for strength, provide a contrast and do-able with hand tools. You could make a dowel jig from some hardwood but would be hit and miss getting accurate holes without a drill press, so splines probably the better option.
Still nice. What kind of music do you have on vinyl?
My collection spans classical/jazz/prog rock/new wave/folk I even have a few Steam locomotive albums, surprisingly relaxing to work to.
Mainly Rock, Prog Rock and Blues, with a smattering of Classical. My T/T is still in the loft, 4 years after i moved house. I've just recently built a unit and got all my albums down but have recently converted to active speakers and am currently researching the best way to connect a T/T to them. Will get something sorted after Christmas and get it up and working again.
Linn cut a grove round the middle and ply triangles glued in the corners, it should be easy to do with your Record 044c, a 12mm grove 3-4mm deep and some 12mm ply, you might need a cut out in one to clear your arm pillar.
I have a Roksan Xerxes with a Artemis arm and a Dynavector 10X5 cartridge.
MrTeroo":vqssg229 said:
Thanks, the lid has a cutaway section for the arm.
Is this the germination of a vinyl club on here?
:D :D
I know quite a few woodworkers and other trades who are Hi-Fi buffs. Must go hand in hand.
I misunderstood because I am describing a thin groove on the top for the edge of the lid to sit in, you mean like this
Yep, it will add a lot of strength to the corners.
You should be able to cut the lid grove with a rebate plane.
