I too have been buying off ebay - a Wadkin BGS 12" saw with a sliding table.
"Major" problems were:
1. one of the bolts for the bearings for the sliding table was damaged. I damaged the bearing bringing off the bolt (£15 + vat for a replacement) since it was a press fit. Made a new bolt in about a half an hour on my lathe.
2. The 12" blade was 30mm bore whilst the saw arbor was 1". Freud told me that reducing rings were now illegal, but luckily the news hadn't got to Belfast where I paid £4 to have one put in.
3. The machine was 3 phase, so I wanted to replace the motor. I had a 2 hp unused one from Machine Mart and having seen a post here about using this, I contacted MM who told me no. I then contacted Clarke International who told me yes. I then went back to MM who told me Clarke didn't understand and that I need clutches etc.. It turns out that MM advertise these motors as having lots of applications: they actually only have one - for fans/blowers. They have a very low starting torque. I emailed someone else involved in machinery who said "go ahead" so I did and put the Clarke motor on. If it burns out it's my fault (but MM shouldn't advertise these so incorrectly). It did cut through a short 4" square piece of "solid" soft wood but I wouldn't want to do so for 8 hours a day.
4. I have an NVR switch (16Amp) which I intend to wire in, together with a foot stop and thermal overload.
So, apart from the motor question, not too serious at all.
The saw came from - I believe - Rothesay Academy (1966 build) and is in good nick. It has stickers saying no blade less than 12" which I don't understand. It also has a side table extension and very, very long bearers for the fence (which I might replace with shorter ones). No mitre, but there are bolt holes in the sliding table - what might have been there? Perhaps ex-pupils from Rothesay Academy could tell me? Some castor system will be used since I need to move it around and it weighs almost 1/2 ton (mostly in the table tops).
I live in an old house with bits always falling off - so the saw is mainly for repair of sash windows etc.. My last machine was a contractor's saw with a hollow in the table which caused me lots of hassle.
Anyway, here's some pictures of it:
Philip
Philip
