Another Mystery Tool?
mahking51
15 Nov 2004
Nr Dorchester Dorset
Seems to be my week for oddities!
This came in a box of Bric a Brac at auction:
Made of cold painted cast iron, the catch at bottom pulls out under a stronngish spring tension but no apparent ratchet to keep it out?
Body is 6" overall by 3" wide.
Some sort of gizmo for hanging pots over a fire?? :?: :?:
Cheers,
Martin
It's one of those things for making queuing lines in banks and postoffices, circa 1800. Picture 10 of them stretched between cast iron poles.
I think it might be a retractable travel washing line - for drying your socks overnight when at a cheap B&B. A bit like this modern plastic one:
My guess is a tool counterbalance, like you see on many production lines, holding up a (e.g.) air spanner weighing 50 Lbs. If the spring provides a force (*) of 55 Lbs, the tool stays up on the reel, but can be pulled down by a force of only 5 Lbs, and put back up using no effort at all.
Your device is much smaller - I'm guessing for holding something like scissors over a shop counter.
BugBear
(* there are interesting items called "constant force springs")
BB, That sounds on the money to me, makes perfect sense.
Also the fact that it is numbered probably means its available in different sizes.
Cheers,
martin
