jimi43
My never-ceasing quest for fine Gabriel woodies took a very definite upward boost today with a little surprise.
I bid and won a little group of four planes which arrived today....
At least two of these are identifiable....but we will go through them in reverse order....
First of all we have this slipped bead with boxed quirk (?) (you are either impressed with this description or if you know me you will know I am hoping I am not talking gonads!
Now...I am just learning here on what these things do but I believe the popular theory is that the removable slip is to enable a small bead to be worked on the edge of a composite profile...(ok ok...I confess...I am reading this from Goodman!!! :mrgreen: )
The likelihood of me removing this slip is virtually zero as the steel screws are well and truly embedded in the slip!
Next along the row we have a rather intriguing plane indeed....
Marked only J.Stubbs which looks too primitive to be a maker's mark...this has a superb profile and a sole insert which appears to be lignum vitae....
In case your eyes are doing what mine did...this is a convex sole! I need to get out and hone this one up because this could be fun...any info guys???
Next...the first of the two named ones...a beautiful little No.6 hollow from Mr George Davis a Birmingham maker working out of 32 Bishop St. between 1823 and 1872.....
That is going to be a temporary keeper until I can find a No.6 Gabriel...and on the subject of this fine maker....
...and with a sole that is amazing! I need some help on describing this and fully understanding it's use but for now...I honed up the iron and it fair whizzed through some beech making a fine clean cut...
What an absolute joy to use...and a Gabriel too...
It also has a removable slip (four screws)...so I am sure it has other purposes than just making nice sliding dovetails...
More help needed on this one...please!!
I just need to get the dust off with meths and varying levels of linseed and we are going to have a play with all of these.
A really nice surprise in a pot luck auction...I'm well chuffed!
Jim
Jim
