deema
So, I’m originally from Yorkshire, and all the jokes about us Tykes being a Scotsman with all the generosity squeezed out, spilt a current in two, short arms and deep pockets are I’m delighted to say all true!
With my proud heritage of make do and mend my challenge has been to resolve the family American fridge that has been misbehaving. Working on the principle that if it’s broken, I can’t break it any further I’ve started on a journey of learning and fixing. Now, I was a life time ago a graduate electronic engineer, and I have to say some of what I’ve done I should score as Z minus as on reflection it was obviously wrong. Anyway, thought Id share what I’ve learned as it may help someone else.
The fridge is a Samsung, ancient like me! The problem has been that the fridge was displaying it was at 3 degrees, however there was a large temperature variant from the top to bottom of the fridge, with the top warming up to circa 15 degree…….good environment for all those bad bugs to have a field day,
The freezer was working fine, and the cold water dispenser was sort of cool but no longer cool.
So, initial thoughts are that the refrigerant is OK, not leaked out, the compressor must also be working as the freezer is still nicely frozen down.
This is the fridge, after I’ve just finished tinkering with it (Round 4, 3 wins to the fridge so far!)
I’ve so far, had three earlier attempts to fix the problem, hence if anyone can spot anything I’ve missed then please shout up.
The inside of the fridge with all the shelves etc removed looks like this.
It consists of the water dispenser reservoir at the bottom, and the two panels which are both screwed and clipped to the body of the fridge. All really easy to remove.
The problem is that the expansion coil is freezing up and the auto defrost system isn’t working.
I believe the fridge and freezer work as follows.
The expansion radiator (well it’s what I’m calling it) is located behind an insulated panel. The compressor pumps when ever the fridge or freezer asks for cooling which feeds both the freezer and the fridge at the same time. A fan on either side then pulls air around the expansion radiator and pumps the cooled air into the top of the fridge / freezer where it then settles back down to the bottom causing a circulation and a constant temperature throughout the unit.
The following photo is the back of the lower panel I removed. It has a fan screwed onto it marked in Red. Just below the fan marked in blue is where the air is drawn in from around the expansion radiator befire being blown out of the top, through the top panel which has vents along its length to let the chilled air into the fridge.
So, the first job was to defrost the unit. Hair dryer came in handy. Next locate the PCB which is in the base of the unit around the back and check the continuity of the circuits. The fridge has two RCDs (Resistance Temperature Devices) to detect the temperature. One located in the upper panel which I’m guessing is what causes the fridge to turn on and off the demand for chilled air, and another located in the top left hand side of the radiator, to I think this regulates the auto defrost cycle.
Autodefrost is I believe achieved by heaters switching on and warming up the area which is insulated from the main fridge / freezer. The fan isn’t on at this time, and as a consequence the main fridge remains cool and is virtually unaffected. After a preset time or once a certain temperature is reached the auto defrost cycle stops and the refrigerator starts up again. Well, that’s my theory!
So, dumb mistake number 1, the obvious is almost always obviously wrong, a mantra I’ve lived by but broke. I found that everything when tested from the PCB connections seemed fine, but I did find that the relay on the PCB for turning on the heaters had failed. So, eBay being my friend a new relay was soon in my hand and a quick soldering job I hoped fixed the job. Sorry no photos of that.
Nope, after a week the fridge was back misbehaving. I don’t have a manual for the unit, and couldn’t find anything online, so a bit of intuition was required. I read that the heaters should be around 700 ohm, and I was reading 2.5K ohm. Strange, heaters normally only fail open or short circuit….dumb error no 2. However, the back of the fridge had a sticker indicating that there are three heaters in the fridge ….weired!
Anyway, the hunt for the heaters began. I only found what I believed as a heater at the bottom of the fridge. A type of heater mat stuck to a plate. It’s located here, the thing with a hole in it.
