This is a present for an 80th Birthday. Size is 480 x 350mm, sides 70mm tall, and 12mm thick. Base 8mm. It is designed to hae a couple of cups and saucers on it, perhaps a plate of biscuits. Nothing too heavy or large!
Next jobs are to plane the mating surface of the 2 base panels, and to cut the handles in the end. Then it will have to go on hold, whilst I wait on some inlaying router bits and the parts for a dremel router base. The base will be raised a fraction to fit the 1/4" grove g=created by the record 043. I wanted to use this plane so I could go carefully.
There is to be initials and a date put onto the long side, or sides. I may do a band of inlay around the top inside- I am yet to decide if it will be a bit much. The inlay will be boxwood stringing, because I have some.
I may dye the wood to even out the colour a bit, then I think i will give it multiple coats of tru-oil. I may have to mask off the lettering with some sanding sealer. I will try dyeing some scrap and seeing what it looks like.
