Am-Tech
whiskywill
8 Nov 2011
Sunny South Wales
I know Am-Tech are not the Rolls Royce of tool suppliers but when using a new 10mm bit to install a wall bracket for a television, I noticed that the third hole looked smaller than the first two. I checked and the tip had disappeared and the helix part of the bit had started to wear into a tapered point. I was drilling through plaster, cement render and Thermalite block. The bit must have been made of cheese.
Wait! what? Are you telling me there is something WORSE than silverline????
O.M.G.
Am-tech are usually bad tools, one off job at best. That being said though, their big jaw adjustable spanner/pipe wrench is superbly made and an absolute bargain.
Some things like drills and Allen keys I would never buy cheap.
Not saying for one moment that they're a good brand, but I've got a set of Amtech step drills and they're actually not bad at all!
I've had a set of Am-Tech files for years... Nowt wrong with 'em.
for removing the backs of watches. it's a ronseal tool, does what it says on the tin. :)
3 sets of pins, easy adjustment in 2 planes with 1 hand.
