Am I going mad?
dance
11 Oct 2010
North Yorkshire
This should work, right? This must be a bug in the software? In a way I'd be pleased to hear I've done something silly...
If anyone's got a spare five minutes to test I'd be grateful!
thanks
dance
11 Oct 2010
North Yorkshire
Can't see the edit button. Forgot to give the URL for the cutlist website.
It's here: http://cutlistoptimizer.com
Basically it's a cutlist web app. I don't like the one in sketchup 'cos it seems to fail to place all panels on sheet goods for no reason. This one seemed good but then I think I've just found it can't cope with more complicated requests.
Deadeye
21 Aug 2017
Buckinghamshire
Looks like a bug.
I tried entering the "won't fit" panels as two singletons, but seems to have the same problem. Doesn't seem to want to use more than 3 sheets.
Argus
21 Oct 2002
Many, many years ago - long before 'apps' - I had a job that used a large amount plywood components.
My problem was to work out, most economically, how many 8 x 4 ply sheets I needed from an extensive and varied component list of plywood pieces of all sizes and shapes.
The solution then was to make up an (Excel) A4 sheet consisting of 96 squares by 48 (each representing and inch (which is what I work in) or 25 mm squares and to draw the components, scaled onto that sheet.
Being on paper, it was also a neat way out working out a cutting sequence on large ply sheets.
It is now in PDF and is invaluable insofar as I can lay out each bit, work out the sheets needed and use up small off-cuts.
If this will solve your problem, avoiding burning out brain cells grappling with an inscrutable 'app' problems, it's yours for a PM with an email.
Adam9453
31 Mar 2015
Essex
I use maxcut (free download) and it’s been brilliant, even with hundreds of panels requiring different stock boards in different sizes and thicknesses. By far the quickest* way I have found to confirm the required amount of boards.
* Unless we’ve drawn the item in inventor, in which case we can use the nest utility to automatically nest the drawn panels onto the required stock boards.
