Quantcast
Alternative Machine Lifting Shackle
pollys13
19 Apr 2009
Swindon
I use an engine crane and correctly rated lifting straps when I need to move a machine. I have four strap ends, to fit over the hook, I can get them all on, with the safety spring clip closed, but is a bit of a struggle and the same with getting..... the sodding things, out of the hook. Is there some type of accessory I could use with the hook or an altenative fitting altogether, to fit into the cranes lifting beam, which would make life...... a lot easier, ideally the cheapest option to do the job. Sorry about the photo in original location is portrait, tried to change no luck.
Cheers.
pollys13
19 Apr 2009
Swindon
Yes I looked into the types of shackles including Ds, tried to work out right size so can fit 4 strap ends, ones that seem large enough can get pretty expensive.
pollys13
19 Apr 2009
Swindon
Another way of going at this, might be to get a set of straps with a lower loading spec adequate for what I want, swings and roundabouts, perhaps cheaper option than a great big shackle. Those purple straps I think are a 1 ton rating.
pollys13
19 Apr 2009
Swindon
Thanks people, what I eventually did, is contacted an Ebay seller of various bow shackles, explaining problem with photo. He came back and said one of these would do the job.
3.25 Ton Screw Pin Event Rigging Lifting Towing Alloy Bow Shackle CE Ebay item 222651234499
A sensible price too, should arrive early in the week.
