Alternative for Birch Ply
A
Anonymous
Guest
Hi all...
Being new to wood, have what might be a simple question but...
Recently bought some plans from NYW, so can build the mitre bench for my workshop.
Plans call for Birchply, the chap at my local yard raised his eye brows a bit when I asked for this, said he didnt carry any stock of that and it was over 40 quid a sheet 8x4. I received a similar reaction at another yard.
Question then I suppose is: Is Birch ply an expensive option? Are there other plys that are just as good. Does anyone have any thoughts on this one before I shell out.
To Birch Ply or not to Birch ply, thats the question....
jasonB
26 Nov 2004
Surrey
The price is about right assuming 18mm thickness, you get what you pay for. Birch ply has more layers of dencer wood and their are no voids so it is a stronger more stable ply, it also has a better quality surface.
If you do a search for birch ply we have covered it before.
Jason
Midnight
11 Oct 2003
Scotland
I donno if this helps or not, but I've found that most projects simply don't need 18mm ply for strength. I've been using 12mm birch for quite a few projects with no cause for complaint... its plenty strong, 2/3 the weight and a bit cheaper than the 18mm stuff....
Its fairly easy to adapt plans to allow for the thinner material...
Nailer
11 Apr 2005
Wirral.....Cheshire
Why don't you just go with WBP exterior grade ply its got good faces and as a rule void free .........i would of thought it was more than adequate for the job and about half the price. :D
It's also readily available at any builder/timber merchants.
A
Anonymous
Guest
perfect, thanks Nailer. Will investigate prices tomorrow.
Bean
12 Jan 2004
scouting about
Not unusual for B&Q, I live almost mid way between Leicester & Loughborough, both have Big B&Q's and the prices are different between the stores for the same goods.
Bean
jasonB
26 Nov 2004
Surrey
If the quality of their £10 a sheet MDF is anything to go buy then the birch won't be upto much :(
Are we talking 8x4 sheets of 5x5 latvian birch sheets :?: or is it just birch faced :?:
Jason
Pete L
24 Aug 2005
Salisbury, Wiltshire
Whilst local timber merchants are usually the cheapest for softwoods, if I need 'run of the mill' wood e.g. CLS pine, in any reasonable quantity I check out the price at the B&Q Depot in (Nursling) Southampton, then get their Customer Service Centre to ring B&Q Salisbury to ask the manager if he/she will match the price. This has worked well for me in the past, as Southampton is a container port and the price of the (inevitably imported) wood is far better than at my local B&Q, or timber yard.
There is also a small Southampton timber yard: -
Arnwood Timber Ltd
61, Millbrook Rd East, Southampton, Hampshire SO15 1HN
Tel: 023 8023 2327
who are "enthusiast woodworker friendly" and keeps decent supplies of hardwood (which I find difficult to source localy in Salisbury !). The owner says he would be prepared to source a load of birch ply if I was in the market for a decent amount (?). I've not put this to the test yet but am bearing it in mind.
Pete L :)
jasonB
26 Nov 2004
Surrey
Agree with you pete, B&Q is about the cheapest for CLS provided you only want it in 2.4m lengths.
Jason
Jake
5 Apr 2004
London
Jason
crooked 2.4m lengths.
jasonB
26 Nov 2004
Surrey
I usually get straight ones from the Croydon depot, just takes a few minutes to eyeball each one before you put them on the trolly.
J
Jake
5 Apr 2004
London
Must have a better turn-over of stock than either of my local two. I can't be bothered buying any construction timber from them. Wickes is a bit better, if you reject 50% you can get straightish stuff. At the B&Qs it would be more like 99%, and it is more expensive.
