Aldi Digital calipers
also..... remarkable good quality and very well built. weirdly accurate for the price.
if your feeling like a total troglodyte, get a second pair and use them as scribes.... be prepared to duck and run if hardcore engineerng tyes se you doing it.
phil.p":260o94qd said:
Just be careful if you only use them once in a while to take the battery out. It goes flat left in.
It does indeed. Why didn't I think of that?
Yes I have some of those, the guy said about the batteries going flat make sure you tighten them right up to lock the slide.
Any movement and the digital display comes back on, other than that very good item
I bought a cheap pair of ebay a while back, accurate enough but couldn't fund the battery cost. Might dig them out now I have been tipped off to remove the batts between when not in use.
I learnt that lesson a few years ago - most of the cases have a space for a spare but I use it for the battery I've taken out.
Rod
I have one of the toolmate brand but since I got a used mitutoyo vernier caliper I hardly ever use it. My eyes are good enough that I can read it and it feels more accurate. I'd like one with a dial someday.
I don't take the battery out and if I had to, I'd just throw it away on account of being defective either in execution or principle.
I picked up a card full of batteries in my local pound shop, so look there first lads
Well if there's something there you'll have to wade through a lot of used diaper bags to get to it, twin boys can poop a lot.
I must have a different battery in my Lidl version of this caliper. I have used mine a couple of minutes a week for at least the last 6 years on the same battery and I have never taken it out. :D
Mine was an Aldi (actually I had a Sealey one that was as bad) - I was using them for maybe a dozen readings, and throwing the battery out the following time. I picked a perfect M&W manual one for £5 at a car boot, I tend to stick to that now.
+1 for the two Lidl jobbies I've got. Irregular use for two/three years on original batteries.
I have a couple of Axminster ones which go flat quickly. I used to remove the battery but I recently bought about 50 for £2 on eBay so I should be OK for a while as long as the shelf life of the batteries is long enough. Very useful tools although if I need really accurate work I always check with my M+W micrometer.
K
