The Shark
Hello guys,
I am thinking of buying the Axminster tool set as a present:
http://www.axminster.co.uk/axminster-st ... rod803508/
Having never made or attached tool handles before,and having looked at the photos on the web page, I have a couple of questions:
1. It looks like a hole is drilled for the shaft of the tool to fit into in the handle. Should this be an interference fit, or does the shaft get glued into the handle? If it is glued, what is the best glue to use?
2. It looks like the ferrule slides over the shaft of the tool, then fits onto a tenon on the handle. Again, is this just an interference fit ( with a trick of the trade such as attaching it when the wood is wet so that it expands when it dries?(don't know if that works, just trying to explain!!)) or is it fixed in place, and if so, how?
Many thanks in advance for any replies,
Malc
Malc
