advice please
Mickfb
9 Jun 2011
Irchester, Northants
I am having a go at turning a box. What is the best tool for Hollowing the box out into the end grain. Tried using a bowl gouge but seems really slow going or is it me doing something wrong (more than likely).
Many thanks
Mick
hi mick
I'm not as accomplished as some on here regards boxes (step forward Chas and George) but heres my tuppence worth. :)
if you have a look here you will see that there are a number of methods. have a look at the Michael Stafford one about halfway down the page for a good guide.
The problem with the bowl gouge is probably down to the bevel angle which limits its ability to cut cleanly into a steep hole.
My preferred method is a spindle gouge from the centre out and then a scraper to profile the bottom inside corners. then lots of sanding :(
hth
Drill out the bulk with a saw tooth forstener bit if you have one.
You can then use a stiff scraper as a boring tool to remove the rest.
A smaller project than this but a similar process
Move on to using your bowl or similar gouges when you have more experience.
If you don't have a stiff scraper you can use a bowl gouge with a traditional straight grind as a boring tool in much the same way, only take small cuts gradually opening up the hole.
Think of the boring more in the nature of metal turning lathe tool use.
Hi
I tend to remove the bulk of the waste with a forstener bit and then tidy up with freshly sharpened scrapers on small boxes. For larger boxes and goblets I use a bowl gouge and scrapers. You may need to check the grind of your bowl gouge, a fairly large angle, (65 - 70 degrees), will leave a better cut.
Regards Mick
My method for hollowing out a box is as follows:
1. Use a 6mm drill hand held in a wooden handle to bore a depth hole.
2. Follow up with a spindle gouge, hollowing from the centre outwards to remove the bulk of the material - or if it's a narrow deep box, remove the bulk of the waste with a large MAD bit (as sold to electricians for cutting odd shaped holes - basically as skeletal version of a saw toothed forstner which cuts much faster and cooler)
3. Finish up with specially shaped scrapers, depending on what shape the inside of the box is to be - squarish scraper for a flat bottomed box, curved one for a box with a curved base.
Thanks for the excellent advice. I have made the box to the best of my abilities, ha ha. Just a couple of pictures.
    219.9 KB
    208 KB
Boxing clever, one down and many more to come judging by the success of that one.
