Sawdust
Can anyone help,
I have an Elektra Beckum HC260 planer thicknesser which has had fairly light use. Generally it works really well but occasionally the drive slips when thicknessing so the wood just stops. I can pull it through and usually the rollers then grip again and all is well. I've checked the belts etc and I know the rollers are still turning but they are slipping on the wood.
What I'm trying to find out is if the rollers are adjustable and if so how to do it.
There are four adjustment bolts under the thicknessing bed but as far as I can tell, all these do is adjust the tension of the springs which pull the rollers down. It doesn't seem to be possible to adjust the roller position relative to the cutters.
The thicknessing table is clean and smooth so I don't think the wood is sticking on the table.
I suppose it's possible that the outfeed (rubber) roller needs cleaning. Can anyone advise what to clean it with?
Thanks in advance for any help
Mike
Mike
