PlacidCasual
Hi Peeps
I’ve built the monsters a treehouse, or at least a clubhouse on an old tree stump. It’s about 1.5m of the ground at decking level and I’d like to add a slide to the treehouse.
Now I’ve checked the price of steel slides and the smallest are expensive enough to air you blanch. My next thought was make a plywood slide as a sheet of 18mm marine ply is about £50-60 so a more palatable cost.
I’m asking if anyone has any advice on making an outdoor wooden slide. Particularly I suppose how to finish it to give a hard wearing slippery surface.
Any advice would be gratefully received.
I’m currently thinking using the track saw to cut an edge mitre (chamfer not sure which is correct) on a sheet to make the slide centre add some sides at the mitre angle probably with some sort of wooden bracket below to secure the sides to bottom. Then sand and epoxy finish. But not tried to do something quite like this before.
