Hello,
As said above, a slight toe out is not the optimal situation, but safe. Dead parallel is best and a toe in should be avoided at all costs. BUT, toe in or out, the cut should still yield a board of parallel width. It will just do it with a wide saw kerf and usually a ragged one. It is called heeling and toeing and saps saw power since the blade has to remove more material, and increases noise. Go for dead parallel blade to fence set up if at all possible.
The only way I can see a saw not cutting parallel boards is if the rip fence is creeping along the rails slightly under pressure of the board being pressed against it. Try clamping the fence on with a g cramp or something, to see if improves things. If this solves the problem, can the rip fence lock be adjusted for increasing the pressure? Is the fence locked at the rear? Is 0.3 mm in 450 actually worth worrying about, or even measurable really?
Mike.
