Howie
Hi
I have a project starting for some TV room units that incorporate glass quite heavily into the design.
The units are being made of a mix of MDF and MDF veneer to which I will be adding 6mm rebates (about 30 mm deep) to some edges and then sticking 6mm toughened glass onto the rebates in the same plane. ie. it becomes one surface of MDF and glass. There will be some degree of structural integrity required of the bond but not too major.
The question I have for you knowledgable lot is this:
The glass will show at points where it has been stuck and I wish the adhesive to therefore be clear behind and not show. I ideally would like the adhesive to have some degree of viscosity to ensure a good bond.
Any advice or questions to clarify my quandary about this would be greatly appreciated.
thanks
Howie
thanks
Howie
