Hello,
I'm building a couple of fairly simple box shelves out of 18mm Birch Ply to mount onto the wall and I am undecided what the best way is to
1. Join the top, bottom and sides.
2. Join the back (if even needed).
3. Mount to the wall.
I wanted to avoid using pocket holes as they might be visible so I thought dowels might be a good idea for number 1 issue.
For number 2 I thought I would make a 9mm rebate around the back of the shelves to slot the back piece in, but I wasn't sure if just glue and nails would be enough when hanging as I thought I would use something like this.
The sides of the shelves will also have extended bits to fit some 33.7mm mile steel rails through which will also act as a support as they will be attached to the wall. There also for design purposes as well.
Good plan or is there a better way? Im fairly new to woodworking so learning as I go.
One other bonus question is the room is carpet, so would it be ok to build my base frame on that or should I measure where the base frame will go and around the carpet to work not he floor boards?
A
A
