A jigsaw that cuts vertically?
johnelliott
16 Apr 2003
Near Swindon, Wiltshire
I own a Bosch jigsaw that is quite good until I want to cut through 40mm material, whereupon the blade wanders and I get a sloping cut. I also own a Makita jigsaw that is very good until I want to cut through 40mm material, whereupon the blade wanders and I get a sloping cut.
Is there such a thing as a jigsaw that is capable of a vertical cut?
I know that basically the fault is with the blade wandering, maybe trying to find the path of least resistance, still, it sounds like an interesting project for a power tool manufacturer
frank
10 Sep 2003
cheshire
john 40 m/m is a lot to ask from a jigsaw can you not use a circular saw first and then trim off with the jig saw ,ie if your cutting the sink insert in a worktop .
A
Anonymous
Guest
John it's not the jigsaw it's the blades i remember a thread on another forum on this very same subject but cant remember what blades were sugested :oops: . I know it was not your average bosch/makita blades. i find downward cutting blades work well for me on thicker material or i just use a router if i want a super cut
Aragorn
6 Feb 2004
East Sussex
Agree - I too have seen blades that cut straight, but can't remember the source. Sorry - but at least you know you don't have to fork out for another saw. The Bosch and Makita are fine - just try to source these special blades.... :roll:
A
Anonymous
Guest
I hav'nt tried them but i think the blades mentioned were Lennox
Newbie_Neil
27 Jul 2003
Nottingham, England
Hi all
The blades you want are made by Lennox. They are the only blade that Festool recommend, apart from their own that is.
http://www.protrade.co.uk/shop/
Click powertool accessories
Click Blades and Holesaw
Click Jigsaw blades
Click Lennox Premium Blades Or Lennox Carbon
Neil
Ian Dalziel
13 May 2004
Scotland
John,
I use the festool body grip which is probobly about the best for vertical cuts because of its deep blade support but it can still cut off vertical if you start to get tired or you are using slightly blunt blades.
Lennox blades are pretty good i used them for a few years, they are great in kitchens for example cutting out hobs and sinks you almost always hit off the metal dowels holding the carcass together(unless you remember to take them out first) these blades just sail through them and carry on cutting. But for vertical cuts the festool blades gave me far better results.
regards
Ian
DAZB
28 Jan 2003
LEEDS United Kingdom
I can recommend the Progressor jigsaw blades for worktops. They are about £13 for 5 but they will sail through any stray nails too and they are worth the money in my view.
