A hungry oil-fired Rayburn.
MixedHerbs
4 Dec 2005
Hollocombe, Devon.
Hello,
I have just had to switch off my oil-fired Rayburn after realising that both it and my oil-fired central heating system have guzzled their way through £400 of oil in two months. I live in a four bedroomed house, not Buckingham Palace.
I moved into this house in August, thus my surprise. The Rayburn is an old fashioned drip-fed model. I have been told I can get it converted to use a pressure-jet system with a timer and a thermostat on the hot-water pipe.
Has anyone out there had experience of such a conversion? If so, are there any pitfalls or points to ponder? Ideally I would want an oven thermostat aswell. Can anyone make any recommendations?
The thing that really annoys me is that I can no longer afford a Lie-Nielson Miter Plane.
Regards, Peter.
I would look at your temperature controls :- thermostatic on all radiators also house insulation and control of drafts and the efficiency of boiler + rayburn(have they been serviced) money spent on controls can give a good return.
The proposed conversion would provide hot water when you need it and improve combustion efficiency
