Tazmaniandevil
One of the things I have most difficulty with is the skew. Not surprising it would seem, as loads of other turners seem to avoid them completely. My biggest problem was always with the skew digging in to the workpiece. My bad, of course, but after many a battered and black fingernail I decided enough was enough. I decided to sacrifice a pile of pine I have stuck under my bench to the skew.
I am getting better, but my goodness it is taking a while.
I turned this little beech goblet yesterday evening, and finished the outside entirely with the skew. I'm quite chuffed with the result, and intend to continue practising on the pine logs until I am happy I can do this without fear. I also need to practice holding the bowl gouge to allow the bevel to stay in contact with the work.
and showing the walls & inside....
Not a good angle, but I was trying to show the uniform wall thickness. Turned out not looking uniform at all.
Goblet is 4" tall, cup is 1½" diameter at the lip, as is the base. The stem is 3/8" at the thinner parts.
