woodfarmer
Here in France pollarding is still in vogue. the 3 meter stems of oak or ash get a haircut whenm the stems are about 6-8 inches in diameter. After centuries of this the top of the 3 metre trunk develops a dome from whence the new stems emerge. This is known as the "tete" in France in English that would be head. One such trunk eventually died and in te course of time rotted away and fell over. and it was brought up from the fields to be cut for firewood. The centre was completely rotted away. Only the outside of the stem and the tete were even good enough to burn. Cutting the tete into five inch slabs I saw that some of the wood was still intact although surrounded by rot. By judicious chainsawing I eventually got a piece out, Much of it was very soft but it seemed to me it had possibilities. bandsawed a circle and started cutting. Ordered £20 worth of CA. used about half of it (60grams) on the outside. Good stuff as it soaks into the rot and makes it stronger. Then cut out the inside and used the rest of the CA. It took three weeks and sometimes I wondered whether instead of buying CA I would have done better to have bought a bowl blank elsewhere.
Any way here are pictures of the slab and it offspring. Please judge the wood, not the turning.
A beautiful piece of wood
and now its offspring..
After my mishap with a horse chestnut bowl exploding I now hold bowls in the chuck in compression using a recessed tenon instead of expanding into a mortice.
