A bit of advice, 'chuck'
sliver
11 Apr 2005
West Yorkshire. UK
Hi all,
Hope you all enjoyed the festivities. Now, I have a Draper WTL12 lathe. I have turned a few items, but nothing I am really pleased with. I would like some advice please as to what chuck would fit it as I don't want the usual marks from the current set up. I have looked at a few, but don't really know which to buy. Has anyone owned one of these lathes & bought a chuck for it? Or knows someone who did? Any advice welcome. Any questions I will try to answer with my limited knowledge as best I can.
Cheers, Sliver.
PowerTool
24 Jul 2005
Darlington
Googling for some pictures of aforementioned lathe,believe it is 3/4" x 16tpi thread - this is the relevant bit to "will it fit?"
Following a couple of recent threads on the "which chuck" theme,Versachuck,Supernova2 and Axminster Clubman series all seem to be a good bet - although all of them will cost more than the lathe :wink: (don't ask me why,they just do..)
Andrew
sliver
11 Apr 2005
West Yorkshire. UK
Hi Andrew,
Quick reply mate, can't you sleep? :lol:
I looked on a site called RDG tools online who are based in Hebden Bridge but I will send then an e-mail to check sizes. Your size check has confirmed I was right in my thinking. I wasn't sure how old the lathe is & was not sure if it was metric or imperial. I was leaning toward imperial.
You know....I can sound really quite inteligent if I try hard enough :lol:
Cost more than the lathe......I paid 26 quid for it on ebay from a man who lived in the next town..Think he moved to Spain or somewhere. So the chuck WILL cost more (dammit) I don't mind if it gets results.
Thanks again Andrew, Sliver.
DaveL
19 Oct 2002
Sudbury, Suffolk
Its because the amount of accurate machining in a good chuck is more (by quite alot) than on most wood lathes. :-k
Argee
2 Feb 2005
Crowborough, East Sussex
What "usual marks" are you getting? These "marks" will be caused by some imperfection in the machinery or setup. I started with a single-pole lathe, which was like a fairy tale - Grimm! The headstock bearing was poor and keeping the tailstock in line was a bit hit and miss, mostly down to the weak locking levers.
That's exactly what I did, but - luckily - I thought ahead and bought a good chuck with a replaceable insert (Axminster Super Precision). When I upgraded my lathe (as I suspect you will end up doing), I just had to get a new insert to fit the new lathe thread and my lovely chuck fitted right on.
HTH
Ray.
sliver
11 Apr 2005
West Yorkshire. UK
Right, having to rewrite all this as computer shut down just as I hovered cursor over 'submit' button.
Ray, thanks for your reply. The marks I refer to are made by the Arbour? I believe it is called. The tapered bit that digs into the wood from the headstock. I'm sounding really thick now aren't I? Seen 2 types of chuck on RDG Tools site, one a taper fit & one a screwfit. I will also check out the Axminster one you mention too. I have two facepates, one left hand thread for the outboard side & one right handed for the inboard side. With a chuck I can eliminate screw holes & the like.
Thanks again. Sliver.
Argee
2 Feb 2005
Right - I understand now - the drive prongs that dig into and drive the wood round. OK - I was concerned that you were getting marks caused by an out-of-true bearing, vibration, misalignment, etc. which does not seem now to be the case. :)
Ray.
CHJ
31 Dec 2004
Cotswolds UK
sliver":1ry4li3y said:
...snip... The marks I refer to are made by the Arbour? I believe it is called. The tapered bit that digs into the wood from the headstock.
sliver, "Drive Centre" is the common term you are looking for.
If you have a a piece that needs to be held between centres but you don't want the marks, try hot glueing a sacrificial piece of wood to it, this can be removed afterwards by careful use of a chisel
paulm
IG paulm_outdoors
25 Sep 2005
North Hampshire
Or just leave a 1/4" or so piece of waste at the drive end and part-off in front of that when you have finished turning......
Cheers, Paul. :D
sliver
11 Apr 2005
West Yorkshire. UK
Ray, sorry I didn't explain very well.
Chas, Thank you, silliest names that escape me sometimes. & thanks for the tips.
Paul, Thanks also for your tip. Chas said I needed to carefully use a chisel, what time can you get here? Sorry, couldn't resist. :oops: :lol:
