If it does not have to move around you could always put a block of wood under the stand.
If it is of any interest I am about to sell a 17 year old Axminster 350 which has a working height of 1.1m I was going to vac it down and photograph it tonight
Claymore":8mn06q84 said:
Hi,
I am thinking of buying the Axminster Hobby Series HBS310N Bandsaw and its a floor standing comes with its own stand BUT I am 6'4" tall and the working height of the table is too low for me
Are you sure it's too low, have you actually stood at the machine in the flesh?
I am 6'3" and I have a Record BS300E which according to the online specs (I'm not at home to check it) has a table height of 990mm, compared to the Axi at 1005mm. I find this table height perfectly comfortable for working at and have never considered it too low (unlike my lathe, which could definitely do with being 200mm higher).
Claymore":2m7xfn2k said:
Hi, No haven't seen the Axi in the flesh but going by the 1005mm measurement i could do with it around another 200mm higher to be comfortable
Actually I just measured mine, surface of the table is at 1070mm, I forgot that I'd built a wheeled platform for it.
1200mm would be just a little high for me, my elbow is at 1160mm with my forearm parallel to the floor.
I always thought it was hight related as I am 6'3" and always found myself bending over to reach things that average hight folk could reach more easily. Anyway one major op and much military grade titanium, semi-porous cobalt and ultra high molecular density polylythene later all is good!
Depending on how much taller you need it you could always make a single draw unit to fit between the base and the machine. Always come in handy to store spanners and mitre gauge for the bandsaw meaning they are always handy
