51mm threaded adapter for Numatic NVD750
Yosarian
25 Feb 2019
Bristol
Does anyone know where I can get an adapter which fits the threaded 51mm inlet and outlet on the NVD750? Ideally to match a 50mm ID hose. Thanks.
Noel":6aumwqfr said:
May not be the one you want (or the price), spec says will screw onto 51mm fitting and taper 58mm OD and 51mm ID: https://www.axminster.co.uk/numatic-nd- ... -id-104971
Thanks, but I think I need the female thread part, rather than male. The threads on the extractor body are male.
Sent from my SM-N950F using Tapatalk
You could contact Numatic direct and ask - they manufacture in the UK.
Numatic are in Yeovil, IIRC.
But you are in Bristol... try The Vac Shop in North View, Westbury Park/Henleaze. They keep a lot of Numatic spares, including motors and hoses - they *might* have what you need although I think the 50mm size might be too industrial forthem - worth a quick call anyway.
