oceanobsession
Hi folks, im looking to fit 4mm t nuts into 25mm birch ply first you drill a 4mm hole then you have to drill a 5mm hole so far into the wood to take the outer diameter of the thread, how do you make sure that the 5mm is in the centre of the 4mm hole, only unlike steel the drill does not follow the shamfer . cheers all phil.
