Lonsdale73
Any recommendations as to which and where to buy?
pcb1962":3dy7y6p4 said:Assuming you mean flexible, I got mine hereLonsdale73":3dy7y6p4 said:Any recommendations as to which and where to buy?
For rigid I use white soil pipe from Wickes
Lonsdale73":2w8073zh said:pcb1962":2w8073zh said:Assuming you mean flexible, I got mine hereLonsdale73":2w8073zh said:Any recommendations as to which and where to buy?
Have you been able to connect the rigid to the flexible? If so, how?
No, you can't stretch the flexi over the soil pipe, I use something like this, not this exact one, probably got mine from Rutlands.Lonsdale73":2tj7kbe6 said:pcb1962":2tj7kbe6 said:Assuming you mean flexible, I got mine hereLonsdale73":2tj7kbe6 said:Any recommendations as to which and where to buy?
pcb1962":5w9zjki9 said:Assuming you mean flexible, I got mine hereLonsdale73":5w9zjki9 said:Any recommendations as to which and where to buy?
Superstrat":3khe4eqw said:pcb1962":3khe4eqw said:Assuming you mean flexible, I got mine hereLonsdale73":3khe4eqw said:Any recommendations as to which and where to buy?
The only 110mm white soil pipe I can find at Wickes is just 850mm long. Is this what you use, or are there longer lengths I've missed?
TFrench":51t6yxre said:Find your local ducting supplier? galvanised spiral duct is literally pennies. It's all designed to fit together too. Try lindab - I've googled it, theres one in lincoln. They have blast gates and everything.
Lonsdale73":2fpg07ut said:TFrench":2fpg07ut said:Find your local ducting supplier? galvanised spiral duct is literally pennies. It's all designed to fit together too. Try lindab - I've googled it, theres one in lincoln. They have blast gates and everything.
Where are you seeing prices?
TFrench":13z65cls said:Lonsdale73":13z65cls said:TFrench":13z65cls said:Find your local ducting supplier? galvanised spiral duct is literally pennies. It's all designed to fit together too. Try lindab - I've googled it, theres one in lincoln. They have blast gates and everything.
I'm not, but we occasionally fit ducting at work so I know how much it costs. The prices on the site distinterior posted look on the expensive side to me. Try going to your local lindab and talking to them. Explain what you're up to and try and wangle as good a deal as possible! Works for me when I buy DIY stuff from trade counters.
