This subject has probably been mentioned before and if so I apologize.
Does anyone use 3D modeling software such as Maya, 3DSMAX, Z brush (commercial software) or Blender (open source and FREE) to help them with design ideas.?
It seems to me that this would be a great way to try out concepts without wasting your precious stock of blanks. Also for things like inside out turning you can actually make a virtual first turning then cut it into however many segments you wish and rotate them to see what effects you can get. The other advantage is it is something you can do when its either too dark in the shed or too late to be making noise. As its free and a very comprehensive piece of software I would suggest BLENDER. http://WWW.blender.org for download.
Not only can you get a 3d representation of your object but you can also add photographic textures to them so they look like a real object not just a grey shape.
Just a quick example.Took about 5 minutes to create.
I know most of these programs require you to learn how to use them but then its a tool and you need to learn how to use any tool.
There are literally thousands of tutorial videos on the internet to help you learn and one in particular that I found great is at
http://www.youtube.com/user/cannedmushr ... ry=blender
I am not an expert on Blender but know enough to get by. I am happy to help with tips and tricks (if I don't know the answer I probably know where to look and find it).
A couple more examples after about 30 minutes tweaking
so realistic you can still see the toolmarks
