Linwoodjoinery
Evening all. How hard is it/ what’s involved/ cost of turning a standard 240v supply into 3 phase? I know that may be a massive question but just general advice would be appreciated
Three phase power is not often that far from your property, the main cable from the 11Kv sub is three phase and houses will be wired in groups across all three phases to help keep it balanced. When I had my supply provided I had laid the duct from the edge of my property all the way to the existing meter under the stairs and provided the Isolator and JB that took the supply down to the workshop. The DNO turned up and dug the hole, luckily my side of the road and ran the 25mm four core cable through the duct and fitted a new three phase meter. All the three phases went to my JB and they ran one phase out back to my household consumer unit. The guy then sat in the hole which was wet and cut into the existing LIVE supply cable that ran up the street to remove my old supply and connect my new cable. Took about 3 hours and £1800. Had they had to cross the road then double it.The snag with a 3 phase supply is not just a case of getting the extra phases (lots of trench’s may need digging from the outside of your property and onto your property)
