200mm fine wire wheel 5/8 arbor
gtchucker09
21 Oct 2020
Bridgwater, Somerset
Hi,
Does anybody know where you can get a fine (0.1-0.2mm wire diameter) wire wheel. I have a 0.3mm brass coated steel wire wheel but it gouges softer metal components
cowtown_eric
4 May 2006
Calgary Alberta Canada
jewelers supply stores have them, , but-often in a wooden hub intended for a tapered shaft, but they often sell adapters as well. But like any wire wheeel, you've got to pay attention to max rpm!
I dunno if a router speed control would work on a regular bench grinder.
Eric
