Can you link two identical 100mm chip collectors to a single 150mm inlet to extract from a single machine? (Using a 'Y' connector, 2x 100mm into 1x 150mm)
Also, could you fix a DX to a wall at 90 degrees, would it affect the impeller to operate from a horizontal axis?
