15/32 drill bit?
nev
21 Jan 2011
The green and wetter end of the M4.
does anyone know where i might find a 15/32ths or 11.9mm lip and spur, brad point type drill bit,( for drilling one half of the jr gent pen kit)?
ive googled til i'm cross eyed and can only find them in the states. even the pen kit seller (timberbits) doesnt have them in stock #-o (plus they are not pointy ones)
just tried a 11.5mm and reamed it up and down a few times, the brass tube went in but the blank split as the glue was drying :evil: and i havent got a 12mm to try.
Bill Mooney
28 Aug 2009
Co. Durham
In Walter Hall's book he says the drills for the Jr. Gents pen are 10.5mm & 12.5mm. Hope this helps.
jumps
29 Nov 2010
kent
not sure why you want lip and spur ? - I use these for drilling pen blanks on the lathe, locating the drill bit direct in the tailstock...they don't wander anywhere and you get a perfect clean cut everytime with no variation in diameter etc
downsides are obviously that you need the right MT tailstock and they become a very 'dedicated' solution; and therefore relatively expensive.
I find both my 1MT chuck solutions provide a little play at the drill tip when pusched, and obviously the thinner the drill the more total movement can occur. At 10mm I am hard pressed to move the drill tip at all (I can't) with these.
I can't comment on the sizes you need at all - I just linked to the size you asked for. I have had excellent service from Andrew (that seller) and he responds well to communication.
nev
21 Jan 2011
cheers jumps , but the morphic waves are not coming through :wink: got a link :?: :)
jumps
29 Nov 2010
kent
whoops.......... http://www.ebay.co.uk/itm/NEW-SKF-D..._Metalworking_Supplies_ET&hash=item336640b6ad
nev
21 Jan 2011
jumps
cheers, sensible option but as you say a touch pricey esp since i'd have to buy a chuck (to hold the blank) too :(
lofty
thanks, good link. bits ordered :)
i think it was the lip and spur bit that was tripping me up. #-o
