brianhabby
My Bandsaw (Axminster SBW3501B) has a 100mm dust port at the bottom on the back. I've used it with various vacs over the years and it has worked fine but a re-arranging of the workshop will necessitate a permanent change to a small vac with a 35mm hose connector. Obviously I will have to step the 100mm down to 35mm at some point. My query is: Is it better to step down close to the tool or close to the vac? Or does it not make any real difference? What do you think?
thanks & regards
Brian
thanks & regards
Brian
