£24.99 Router Table
DaveL
19 Oct 2002
Sudbury, Suffolk
waterhead37":2n077ses said:
I reckon it's the £3.99 planes that take the award - Alf will love them..
The scary thing is last time they had them someone was reselling them on ebay. :whistle:
Gill
3 Sep 2003
Lincs
If I get an electric glue gun, I'll be able to forget about learning to cut dovetails, won't I :D
Gill
A
Anonymous
Guest
looks good enough to use. I have bought inexpensive tools from Lidl and have been quite impressed. with the value.
DaveL
19 Oct 2002
Sudbury, Suffolk
JMT, I agree with you, I have quite a collection of stuff from Aldi and Lidl, but the planes did not inspire confidents when I looked at then in the pack last time. 8-[
Does this mean I am now part of the Cheap Skate section of this forum? :oops:
Matt1245
26 May 2005
Manchester
Looks identical to my netto £24.99 router table, which has had some good use and stood up very well to it. Made a full set of kitchen doors and drawers on it. It's not much diffrent than other branded table which cost far more money.
Matt.
j
27 Sep 2005
Milton Keynes
How do the routers attach to these? Are the hole patterns stndard?
I'm undecided about either getting one of these and using it for a bit then wanting a better router and having to junk this one. Or just go for a good router now and hope that i'll still enjoy woodworking to get my money's worth out of it.
I don't want to spend a fortune on tools only to find that I'm either not any good at woodworking, or it'll cost me twice the price of pre-made stuff just to buy the timber, then i'll have to buy a jointer, plainer/thicknesser etc just to get it into a useable state.
I'd like to get a good router, been looking at the freud. I'd also like to buy a table for use with it, any recomendations? I could build my own, but I think i'd rather buy one (if it's not too expensive) then I can actually use my tools instead of making attachments for tools :)
Sorry for the rant
J
wizer
3 Mar 2005
I would buy this one if you are a beginner. These cheap router tables have come up a few times and I have yet to hear a bad review of one. I was going to buy the netto one not so long ago but it was sold out by the time I got there. I now have the Triton but from what I have read these tables are real value for money. As long as you get a good router to go with it, then it should be fine. As you say, when you gain more experience you can make a decision wether to make a router table, buy one or indeed stick with this one.
Be quick tho, these deals go very quickly!
Adam
10 Sep 2003
UK
j":24wwpmwy said:
or it'll cost me twice the price of pre-made stuff just to buy the timber, then i'll have to buy a jointer, plainer/thicknesser etc just to get it into a useable state. J
Hmm. Have you been to Ikea recenlty? Everything there is cheaper than if you bought the timber alone. Never mind kitting out your workshop etc.
The difference is that when you make an item yourself, properly built and in good wood, you'll keep it for life. Ikea furtniture is unlikely to last more than 10 years, and certainly I've found each time you move any flat pack furniture the stress really shortens its life span.
Adam
j
27 Sep 2005
Milton Keynes
WiZeR":3v07yu5e said:
I would buy this one if you are a beginner. These cheap rouAs long as you get a good router to go with it, then it should be fine. As you say, when you gain more experience you can make a decision wether to make a router table, buy one or indeed stick with this one.
Thanks for the advice, how would you rate the Aldi router (also on offer)
I actually bought it a couple of years ago. It seemed ok for what I used it for (just some pine) It's my first router.
I could consider buying a better one, but then I'm not sure if it would attach to this table.
Ta
J
j
27 Sep 2005
Milton Keynes
Adam
Yes, I agree, I was actually thinking of the hardwood garden bench I paid £20 for last year (end of season clearance), and the hardwood octagonal garden table top for £1 (missing legs)
To buy the wood for that would probably cost double.
I think i'd build stuff more for the enjoyment, rather than any potential cost saving, but sometimes I wonder if it is worth it.
Maybe i'm lacking in inspiration (as well as skill) I'm going to attempt a couple of small projects that I should be able to do with some fairly cheap tools and see how I like it.
I'm currently knocking up a couple of picture frames, and i'm planning some small wooden boxes.
apologies for hijacking this thread. :)
J
wizer
3 Mar 2005
Ta
J
I bought a cheap Ferm router when I was starting out (not so long ago). I used it a couple of times and it was fine but for some reason I felt I needed something 'better'. Now I have a Triton router I have used the Ferm more than ever. I'm not saying the Triton is rubbish, far far from it. But since I have gained a bit more experience, I have found the Ferm very good for small light work. I would say for table mounting you will need something a bit more powerful and better made than the one aldi are offering.
j
27 Sep 2005
Milton Keynes
I take it this table is not a good companion for the Freud 2000
Any recomendations of a good table for this router?
I'll consider my options once i've seen it. I'll have a look at the Aldi one in store, see if I like it.
Thanks for all the advice.
J
WoodPecker
30 Sep 2005
Leitrim, IRL
Making your own router table doesn't have to be a mammoth project, I made one a few years ago when I needed one in a hurry and I reckon it took about 2 hours :shock:.
Basically all you have to do is cut two pieces of plywood (each one the size of the required router table top)
Take one sheet and cut out a rectangular piece from the middle of the sheet with a jig saw, making sure that the hole is big enough for your router to fit through.
Cut a slightly larger hole in the second and keep the piece you cut out as this can be fitted to the base of your router (Better to cut a slightly larger new piece to allow for the width of the jigsaw blade)
Glue the two plywood sheets together, put some weight on it and make sure the sides are lined up.
Take your B&D work bench (Everyone should have one) and open it fully, measure the opening distance and attach some L brackets on the bottom of the plywood (Small hole side) far enough apart so that they will fit into the work bench.
Fit the base on the router (And plunge a hole through) h and make a stock from two very straight pieces of 3X2 (Glue and screw together either side of the middle and cut out a gap in the middle).
Pretty basic but it does the job, It's a few years since I made it as a temporary solution and I'm still using it. And of course it folds away.
I can post some pictures later in the week if anyone is interested.
I meant to say, the PARKSIDE range that LIDL sell are great for the money, I have the power saw and the plane, Really well put together. But don't buy the glue gun, the glue gets on the inside after one or two uses, even if you keep it pointing down all the time. Don't know if the ALDI glue gun is any better.
Alf
22 Oct 2003
Up the proverbial creek
It's worth it; and even more so if you need things that you just can't buy. Something built-in, to fit a certain spot in your house, to house a particular item or items, or to give to someone else etc. Definitely worth it.
And yes, the planes are a joy. Karl Holtey better watch out, eh? :lol:
Cheers, Alf
j
27 Sep 2005
Milton Keynes
Thanks, I've actually got a simple wooden router table that i'd made, but was thinking of something a bit more sophisticated, wiht a miter slot and dust extraction etc.
I've been told here and over on uk.d-i-y many times how dangerous my router table is, and If i'm going to use it a lot more, i'd like something a bit more suitable.
Matt1245
26 May 2005
Manchester
No, won't be anygood for that freud, the table is designed to take a 1/4" router. You'd need a bigger table for the freud.
Matt.
A
Anonymous
Guest
I have just perchased the Aldi router table to replace my home-made one.
It seems to be OK and with the table extensions fitted is far better than some of the cheaper ones I have seen.
It takes a router with a base up to 150mm dia so DON'T buy the router on offer in the store expecting it to fit - that has a dia of 160mm.
Its still a good buy for the money and will replace the one I shall use in the table.
