 Reply
As it is not in the UK
42
98%
1
2%
User avatar
By sometimewoodworker
#1094512
More from November
Adding money to the foundations for luck
Neighbors helping putting up one of the first posts
Neighbors helping putting up the other of the first posts
Thin concrete base
Correct, but uncommon, spacers under the rebar
Irrelevant banana plants just beside the house
Again a common sight in the UK a concrete bucket, but less common in Thailand
We are going to use a UFER ground but our architect decided to add a ground spike as well
An unusual, for Thailand, spiral stirrup.
Preparing for posting at 3:47 p.m. Thursday, 13 October 2016 (my class is busy now)
You do not have the required permissions to view the files attached to this post.
By phil.p
#1094524
Bananas? Common in Thailand, less common in GB. I've just been told to cut back the one on my allotment as it is too big and they don't allow trees. I don't think they liked it when I told them bananas aren't trees. :D
User avatar
#1094554
phil.p wrote:Bananas? Common in Thailand, less common in GB. I've just been told to cut back the one on my allotment as it is too big and they don't allow trees. I don't think they liked it when I told them bananas aren't trees. :D
Of course you are completely correct it is a grass as is bamboo and papaya. So the jobsworths should have banned very large/tall plants :lol: because they would probably allow a box tree.
By sunnybob
#1094574
Theres lots of banana plants / trees /herbs/ whatever, around here. You cant believe the space a single plant takes up. Incredible amount of green material for a few fruits/ vegetables/ whatever, and I dont even like them.
User avatar
#1094802
November December
More foundations
Foundations completed and back filled
Keeping them damp for the first week
The house and workshop are going to be raised off the ground for a few reasons including, ease of repair of plumbing pipe if needed, making it more difficult for snakes, centipedes scorpions and other wildlife to get into the house/workshop.
Starting on beam supports
More of the women construction workers
The women are not limited to the lighter jobs
The garden provides some free food for the work gang
The workshop is being built to be able to park a car or few if we need to lock them up if we want to have a holiday. So some of the beams have a significant amount of rebar
Preparing for posting at 8:27 a.m. Friday, 14 October 2016
User avatar
#1095826
December continued
The rebar framework
The way locals mix concrete
SWMBO is proud of the fish she can get from our pool
A rarity in Thailand, a builder who does read the plans
Shutting going in for the floor beams
The shower/toilet gets a solid floor
In the midst of the new there is a reminder that death is something that comes to us all.
Nui's grandmother died of a cerebral haemorrhage.
This is a body freezer
Part of the ceremony
The concrete poor is finished and ready for the floor planks
Preparing for posting at 2:48 p.m. Tuesday, 18 October 2016
User avatar
#1096079
December continued
A Thai cremation is a spectator affair with family and friends paying their last respects.
Then the monks give a last blessing
And finally the body is cremated
Back to the building, concrete planks are put down
Rebar is put on top and formwork is put in place
They did use a helicopter but might as well have not bothered as they didn't leve a flat floor.
I managed to fly in on Christmas Day, as you can see in Thailand we can carry a few more people in one pickup than would be legal in the UK
Preparing the column shuttering
A crane carried concrete bucket is much easier than individual builders buckets
Preparing for posting at 12:59 p.m. Wednesday, 19 October 2016
User avatar
#1096084
Christmas/New year
Wrapping the posts, using up a great auction purchase from 40 years ago
The new year holiday break
This is the time of year when the sugar can is burned to get ready for harvest
New year starting on some top beams, concrete and steel
Getting the front stairs ready steel I beams for the car ramp and parking/loading dock
What happens if you get your measurements wrong
One of the two trusses that will be about 18 meters long
Preparing for top concrete beams
Preparing for posting at 6:17 p.m. Wednesday, 19 October 2016
User avatar
#1105556
There's been a little bit of a hiatus due to replacing my iPad
Anyway continuing;
Starting with papaya for the main Issarn meal of somtam
Getting the stars ready for pouring
Spiral wound stirrups for round posts
Re-enforcement for the security room
A high tower is needed to place the forms
The "finished" steps (there is a bit of problem with these, more later)
Shutting going up for the security room
Final welding on the 2 X 18 metre trusses
Truss placement
Fixing the trusses in place
Preparing for posting at 3:01 p.m. Tuesday, 22 November 2016
User avatar
#1105558
With insulation being at least as important as in the UK the walls are going to be double AAC block construction
The spacing of the skins is dependent upon the thickness of the posts
AAC blocks
A wall in progress
The roof steel is going up
The inside of the security room doesn't look too good at the moment
Oxypropane cutting to length
One of the big advantages of AAC bloc is that woodworking tools work.
Another advantage is the very thin "glue" line needed
Double walls mean that electricity and water pipes can go in the voids
Preparing for posting at 3:34 p.m. Tuesday, 22 November 2016
User avatar
#1105602
Spacing and height for some of the workshop power sockets
These are kitchen outlets, over and under the work surface.
The roof substructure is close to finished
More workshop outlets
We had a problem with the water supply, so the fire brigade was used to supply water to each house!
Roof frame again
Workshop outlets
Its a building site
Outlets at about 50cm intervals
Preparing for posting at 22:30 p.m. Tuesday, 22 November 2016
