Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
User avatar
By Steve Maskery
#998579
I've had a jig in my head for quite a while, so today I started to make it.
First I routed a groove down the length of a piece of MDF. It's wide and deep enough to take a flange nut.
I then drilled a couple of holes
and routed a groove between them
followed by a larger hole for hanging and access to the groove.
I measured the distance from the front of my bench to the back face of my bench dogs
Back on the router table I routed a rebate across one end, as wide as that measurement
and glued in a notched piece of wood
It's good, isn't it?
By Monkey Mark
#998593
That is, without a doubt, the best looking thingmibob I've ever almost seen! :)
User avatar
By Zeddedhed
#998601
Thats not a Thingmibob.
It's a DooHickey. Everyone should have one.
By Monkey Mark
#998618
Is it...... a bench dog assisted dado jig with adjustable stops?
By Monkey Mark
#998624
Something to do with your new shutters?
User avatar
By Zeddedhed
#998663
Steve Maskery wrote:You guys are not even trying.
S
My missus says I'm extremely trying.
But then she also says that absent minded nose-picking whilst watching TV is a disgusting habit, proving she doesn't know what she's talking about.
User avatar
By Droogs
#998675
You're doing it, aren't you! You've managed to think it through, the sparkly flash of inspiration has struck (probably around 04:27 this morning) and you couldn't go back to sleep at all could you? You just had to make it and test it out. 'Cause this is definately the answer, you're sure of it. It's gonna make you a fortune, everyone on UKW will want it and at £300 a pop it'll be seen as a snip a bargain that we can't live without. It's the Steve Maskery Doohicky Thingymajig Whatcha ma Flip Mental Japanese 3 way Joint Making Jig
](*,) (hammer) :tongue9: :tongue9: :tongue9: :tongue9:
User avatar
By Droogs
#998679
PS:
When will it be available to buy or rent?
