 Reply
By smiler6303
#460537
Hi Folks, I need your help ! I've just been offered a K5 machine, (sight unseen as yet), but I know nothing about them. Were they a good machine? what should I look out for? what sort of price range?
Any help would be much appreciated,
smiler
User avatar
By Lons
#460660
smiler6303 wrote:Hi Folks, I need your help ! I've just been offered a K5 machine, (sight unseen as yet), but I know nothing about them. Were they a good machine? what should I look out for? what sort of price range?
smiler
Hi
I bought one of these in 1987 just before they changed to a Bestcombi.
It's an excellent little machine as long as you remember it was aimed squarely at the home user.
All you need to check really are the usual bearings and motor. Look carefully at the condition in general and tables especially which will soon tell you how hard a life it's had.
Despite owning independant full size machines, I've kept the K5 and still use it regularly if I need something dome quickly, (my machine shop isn't set up yet and very easy just to pull out the K5).
Check what the machine has with it.
Is it 5 function? ie slot morticer included.
An extension saw table is useful
What tooling is included
All guarding to moulder and fence for saw etc
remember that apart from belts, you won't easily get spares but it's a simple set of independant machines linked to 1 motor so easily repaired.
Note limitation in tooling size and especially the 20mm spindle (I bushed a cutter block down from 30mm though).
specs:
Gen dimentions - 1015 x 555 x 620mm - weight 65kg
Motor - 1100wt (1 hp)
Saw - rise & fall (45d) - blade 200mm - depth of cut 60mm
Planer /thick - w = 149 x d = 100mm 2 knives HSS
Sp Moulder - Spindle 20mm (30 x 3mm slot)
Tool max h = 80mm dia = 100mm spd 5700rpm
slot morticer - Mortice len = 110 d = 90 height adjust = 50mm
I've got all the original docs including assembly, catalogues, accessories and price lists (out of date) as well as a couple of test / reveiw articles from that era so if you need info just pm me.
Hope that helps
I
By smiler6303
#461015
Lons, many thanks for your speedy and knowledgable observations!
I went to see the machine tonight armed with your checklist, the machine is complete with all guarding some moulder tools and spare saw blades
I could see or feel no play in the pulleys and the tables looked good and square. the planer would need new blades,all in all a good honest machine, BUT not for me... :
the owner is looking for circa £300 So if any body else is looking for a K5 please let me know and I'll pass on the details
Once again many thanks, smiler
User avatar
By ColeyS1
#461030
Hi Smiler6303. I also saw a k5 machine for the first time at the weekend. First impressions, were what a handy and cleverly thought out little machine it was. Ideal for the smaller workshop. I took a few pics as i was so surprised. Hopefully you wont mind me showing them here.
If i didnt have a few bigger toys to play with, i would have been interested. Everything all on one mobile trolley. Be great if space were a problem. Your own woodworking factory on wheels 8)
Simon
User avatar
By Lons
#461147
That's exactly how it was marketed and why it was popular. At the time I was moving to a new house which needed major surgery and little time to set up a workshop.
I needed to produce mouldings to match existing not easily available, Make unit doors and god knows how many other things.
I liked the idea of tucking it in a corner of the garage and it being accessible within minutes.
I researched fully and liked the fact it was seperate machines rather than integrated like its' competitors.
Cost me £800 around in 1987 not really cheap but I've had 22 years usage and it's amazing what it can do with a little ingenuity.
By permartinroos
#572526
Hello everyone
I am in the same situation - just purchased a Kity K5 really cheap ( £ 50....the seller did not know what it was... ) and it is in good condition with a lot of extras going with it. However I am facing this 20mm/30mm problem too. So does anyone have a moulder head for this one, or a link to where it can be found.
But first, most basic, another question: Are you supposed to shift the belt by hand between the three functions by rolling and sliding it off the wheel ? Same belt for all three ?
And: I see on these postings an instruction booklet. Most needed as you hear as I am totally new to this, but have built some furniture using handheld tools. Can I ask for a copy of the instructions booklet , or borrow it and make copies and return, or any other solution. I can pay you for that.
Finally it was encourageing to read these postings talking nice about this combination setup, as the space saving quick ease was why I bought it.
Yours
/ Roos
Stockholm
By permartinroos
#572527
[I am in the same situation - just purchased a Kity K5 really cheap ( £ 50....the seller did not know what it was... ) and it is in good condition with a lot of extras going with it. However I am facing this 20mm/30mm problem too. So does anyone have a moulder head for this one, or a link to where it can be found.
Yours
/ Roos
Stockholm
User avatar
By jasonB
#572553
Yes just roll the belt on/off while slowly turning a pully by hand.
You can use a top hat reducing bush to fit a small 30mm block onto the 20mm spindle, something like this but 20mm bore
Jason
User avatar
By Lons
#572680
Hi Roos
what Jason said is exactly how you change over the belt. It takes just a few seconds once you are used to it but there are 2 things you should be aware of
1). if you overload the saw it will shed the belt. A good thing for safety so isn't a fault with the machine
2). When finished with the machine, it is good practice to slip the belt off as it is easy to forget which machine it's on and it could catch you by surprise next time you switch on. it sounds obvious but easy to make a mistake and cause an accident.
Regarding the spindle shaft. as suggested you could use top hat washers. Those weren't available when I needed a solution so I just got a local engineer to make me a couple of sleeves at 20mm bore / 30mm external and a few mm smaller than the depth of the block. I also needed a washer on the bottom of the shaft but the original top washer grips the block well.
It's also important that you sequence your work carefully for example, to use the saw, the guarding on the spindle moulder must be removed so you need to do all the sawing first for obvious reasons. It doesn't affect the planer / thicknesser.
I scanned the whole instruction book for another member recently so I have it saved as well as some original price lists and brochures. They are in PDF format so you will need Adobe reader but it's free off the web if you haven't got it. You could view on the computer or print off.
If you want them just send me a pm with your email address and I'll send to you. there are 3 files in total at around 4 or 5 mb each.
cheers
Bob
By permartinroos
#573574
Jason/Lons
Thank you for advice on how to get started with the Kity K5. I had the circular saw blade sharpened by a professional and received it today, it now cuts like a razor silent and neat. Also realized there was a handy aluminum quick slot for shifting saw blade ( I dismounted the whole support board the first time.. ). The saw is weak and you need to feed it slowly but makes nice cut surface. There is also a support arm for selection of angles.
Instruction book from Lons on PDF - YES please !
Would be most appreciated and read over and over.
My email address is pr@bostream.nu
Tried to reply by "PM" but not in operation, it said I had to participate more first....ok, will do.
So there is an instruction for the Kity K5 scanned into PDF , of value for future users (I write this sentence as it will be search-able, it took me several days to find this forum so now maybe easier for the next one). Also tried to get in touch with the company that merged with Kity but no reply yet.
Guess I will be back when I get the planer and moulder in operation. Intend to build some boxes and drawers for my shop and maybe later on try furniture. Ultimate fantasy: a wooden greenhouse
/Roos
Stockholm
User avatar
By Lons
#573883
Email and pdf files sent Roos - let me know if any probs receiving or opening them.
As far as searching for them, you won't find the files on the web as these are what I scanned from my own originals for a forum member.
if anyone else needs them, i'm quite happy to send however.
cheers
Bob
By bigplum
#573987
hi, would it be possible to have a copy of the instructions too?
I bought a (nearly)complete but dismantled K5 some time ago
I'm also after a ripping/guide fence for the saw if anyones got a scrap or cheap machine
thanks
Cliff
User avatar
By Lons
#574159
bigplum wrote:hi, would it be possible to have a copy of the instructions too?
thanks
Cliff
PM sent
By deadwood
#581223
Hi I am a new member and I am looking for a combi machine. The Woodstar for about £ 800 looks suitable has anyone had experience of this machine?
The Kitty K5 may be of interest if I could get a used one.
By michaelo7800
#583593
Hi, would it be possible to also get a copy of the manual. I am reassembling my machine after many years in boxes and the manual seems to be lost in the domestic filing system.
Thanks,
Michael
