Dalboy
During the winds I lost my roof on the wood store when I inspected it the whole store needed replacing as it had been up for so long. So long in fact that when I first built it I did not know much about woodwork. As can be seen from the amount of roof support I had.
It took just over two days to empty all of the wood from there, I was surprised at how much, most of it went into the other store which I can no longer move more than a couple of steps into now.
This is going onto a concrete base so no floor needed the lower feather board in protruding below the bottom frame and the two end panel the feather board is longer at one edge to cover the back panel ends.
The roof damage
All wood ordered as well as roofing material and progress began just after the weekend as it was raining like mad.
Surprising but for the size of the woodpile for this build that it is enough to complete it except for some guttering which I will be adding.
First was the rear panel which was the largest one.
The first end panel
I used the first end panel as a templete as that was all squared up the main difference is the centre support is more to one side to allow for the door
The roof damage
The first end panel
